It is currently Fri Aug 08, 2025 3:55 am
Post new topic Reply to topic  [ 40 posts ]  Go to page Previous  1, 2
 Post subject: Re: Side Laminating jig
PostPosted: Sat Nov 04, 2017 7:06 pm
I use West system epoxy. I have found that drying the veneers before laminating adds to the stability. I leave the sides in the form for several days to a week until the epoxy is fully cured. Very little to no spring back even if the sides sit on the shelf for months. I do get some "bleed through " with epoxy, but since I pore fill with epoxy this is not a problem.
PostPosted: Sun Nov 05, 2017 1:14 pm
I'd use West or Unibond. I prefer Unibond because it dries like glass and doesn't bleed through. The downside is that the resin only comes in large quantity and has a shelf-life.
PostPosted: Sun Nov 05, 2017 1:39 pm
Both West Systems epoxy and Unibond 800 will bleed through depending on the porosity of the wood. But they both have thickeners or additives that you add to make the glue more viscous and will bleed through less. I did a bunch of test sides with both glues and I could tell little difference in the resulting pieces. I finally settled on the epoxy due to the ability to use an epoxy pore filler that hides bleed throughs, as Clay mentioned.
PostPosted: Tue Nov 21, 2017 8:01 pm
First name: Joey
Last Name: Holliday
City: Palmetto
Zip/Postal Code: 34221
Barry Daniels wrote:
Epoxy makes for a much more stable lamination. The water in Titebond will make the sides move around after removing from the form.
Unfortunately I had already laminated the first set of sides with titebond before I read this. It's alright though, I figured that I'd just do both and compare the two. I have West Systems and Titebonds both handy in the shop. I do hate the smell of epoxy though and it burns my eyes. Anyway it does seem like it cures much harder. I don't have the epoxy offcuts yet but the titebond ones potato chipped. However, I am very happy with both results. So much so that I'm about to remove a tail block from an unlaminated side set and go ahead and laminate that one as well even though it's at the lower end of the 6 in the works. I don't believe I'll ever build another guitar without laminated sides. I had laminated before but I did not get the results that I got with the new jig. My only regret is not building two of them, so I could do each guitar in the same session and let them cure at the same time. I don't have enough C-Clamps for that anyway though. That will be something to do for the next round though. Pictures to follow.
PostPosted: Tue Nov 21, 2017 8:05 pm
First name: Joey
Last Name: Holliday
City: Palmetto
Here’s the coco/mahogany with Titebond.
PostPosted: Tue Nov 21, 2017 8:08 pm
First name: Joey
Last Name: Holliday
City: Palmetto
Second coco with West Systems Epoxy (haven’t trimmed the rim yet.
Not pretty but it works [:Y:]
PostPosted: Tue Nov 21, 2017 9:33 pm
"My only regret is not building two of them, so I could do each guitar in the same session and let them cure at the same time. I don't have enough C-Clamps for that anyway though"
I have laminated both sides at the same time on the same mold. The slight difference in size isn't real noticeable after they are trimmed and put in the outside form. Putting a thin metal slat between them might help with the flatness ( I sometimes use HPL ). When doing that you have to be careful with orienting things - there is no "unbending" laminated sides.
And to play the broken record one more time - drying out the veneers before laminating with epoxy seems to add stability to the final product.
These users thanked the author Clay S. for the post: fingerstyle1978 (Tue Nov 21, 2017 10:20 pm)
PostPosted: Tue Nov 21, 2017 9:50 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
I /ve used UF glue, epoxy, system 3 and titebond 1 .If your careless like me , you can miss an open slight seam and have to reglue . No worries
PostPosted: Tue Nov 21, 2017 10:40 pm
First name: Joey
Last Name: Holliday
City: Palmetto
I'll use my steel bending slat next time. I'd also like to get some steel strips installed to reinforce the MDF and make the clamping pressure more even so I can really tighten the C-Clamps down without worrying about having uneven pressure result in a slight deformity.
I'm not too worried about that potochippiness at the ends though. I bend them longer than they need to be since the ends tend to do that and they fall outside of the clamping area. The worst (if not all) of it can be trimmed off before gluing to the blocks. Seems to work well so far. Maybe I'll add a few more clamping cauls and clamps down the line to eliminate it even further. Too many other things to do at the moment though!
These users thanked the author fingerstyle1978 for the post: Ken McKay (Sat Dec 02, 2017 8:32 am)
PostPosted: Tue Nov 21, 2017 10:43 pm
First name: Joey
Last Name: Holliday
City: Palmetto
I did that with a set of Narra before building this jig. It was actually the reason I built the jig, but I was able to reglue as well and everything looks good now. I only worry that once the binding channel is cut another area slight space will show itself. I'll just re-glue if that's the case but it slows things down.
PostPosted: Wed Nov 22, 2017 9:07 am
"I'd also like to get some steel strips installed to reinforce the MDF and make the clamping pressure more even so I can really tighten the C-Clamps down without worrying about having uneven pressure result in a slight deformity."
I've glued formica on some of my bending forms to create a smooth surface and the kerfkore also has a smooth face. I'm laminating the old thicker veneers, but still they are veneer, so the smoother the better.
Also, again, I leave the laminated sides in the mold for about a week until the epoxy fully cures. After that I have had some sit on the shelf for over a year and still hold their shape.
These users thanked the author Clay S. for the post: fingerstyle1978 (Sat Dec 02, 2017 2:05 am)
PostPosted: Sat Dec 02, 2017 2:09 am
First name: Joey
Last Name: Holliday
City: Palmetto
A quick update. Here are the cutoffs of the laminated sides.
On the left is flat sawn Cocobolo laminated with mahogany using West Systems epoxy.
On the right is perfectly quartered Cocobolo laminated with mahogany using Titebond II.
Although both rim sets are perfectly acceptable (both are pretty flat) I do believe that I will sleep better using exopy for laminations. It seems that the water in the Titebond may be the culprit.
PostPosted: Sat Dec 02, 2017 10:29 am
It only has to be pretty if you're posting build threads for customers. ;)
Cool experiment and I'm glad you're getting the results you're after.
These users thanked the author James Orr for the post: fingerstyle1978 (Sat Dec 02, 2017 11:10 pm)
PostPosted: Thu Jan 18, 2018 11:29 pm
First name: Joey
Last Name: Holliday
City: Palmetto
I am glad you had good results James. I still have concerns about sufficient clamping pressure in your waist though. You can see that the waist is the last place where the bag comes into contact with the wood and the bag has to stretch a bit in that area which also minimizes clamping pressure.
The bag actually slides down the side as it's pushed down into the waist thanks to the breather mesh. If you want to picture it, the breather layer is like window screen material, made of some kind of plastic material that the glue doesn't adhere to. It provides for both even air flow so that you have even vacuum pressure, and a sliding surface that the bag can glide along so that every area gets clamped with even pressure. Without it, the bag could definitely get choked at points.
Another thing that is helpful is that similar to Nigel's caul, I'm taping the waist down. My sides conform pretty well to the mold and to each other, and the little bit of pull from the tape keeps everything in place.
It's so easy to do in practice, too. Just brush on the Unibond, tape things down, slide it in the bag.
Here is a closeup of the waist. The dark sliver towards the notch for the X is a grain line.
Where do you get your kerfing from? I'm looking to try a something different and that looks interesting.
PostPosted: Sat Jan 20, 2018 12:24 am
That's the multi-axis kerfing from Kevin Ryan, previously known as A4. It looks like production's suspended for a bit right now.
These users thanked the author James Orr for the post: fingerstyle1978 (Sat Jan 20, 2018 4:04 pm)
